Brief Description: Connected Wires to Relays/Clamped Tube-Firewall
The P3 and K1 wires were screwed to the master relay and the starter relay, respectively. The wires were run thru the firewall with the P1 wire from the master relay. The wires were then run thru plastic tubing which was run vertically up the inside of the firewall. The tubing was clamped to a vertical support at the top and the bottom.
P3 and K1 wires attached to the relays
The wires coming thru the firewall and run thru the tubing
