Baker's RV-6
Date: 9-13-2011
Number of Hours: 3.00
Brief Description: Made Another Wire Bundle from EMS to Right Side
The remaining wires from the EMS that need to be routed to the left side, along with the two wires from the alternator, were separated from the last few wires. The wires included: #1-Primary Power, #2-Keep Alive, #3-Primary Ground, #4-GP 1, #13-Ground, #14-Fuel Flow Input, #20-Fuel Level 1, #22-GP 2, #32-RPM Left, #33-RPM Right, These wires were included with the two wires from the alternator, the red-alternator field and the white-alternator out/low voltage. The wires were run thru a length of expandable sleeve and heat shrink was applied at each end. The bundle was run thru the hole in the rudder pedal support bracket.
The wires were labeled at the left side of the bundle as they come out.
The GP 1 wire will be used for the OAT sensor and the GP 2 will be used for the flaps position.
The right side of the wire bundle
Red wire is the alternator field wire--white wire is alt out/low volts
The left side of the wire bundle
