Brief Description: Drilled Firewall for Alternator Wire
A 1/2" hole was drilled in the firewall for the alternator wire to be run thru. The #8 alternator wire had a terminal crimped to it. Two plastic bushings, one larger and one smaller, were inserted over the wire and into the hole. This hole will need to have Proseal applied over it to seal the opening.
The ammeter shunt with the wire from the master/starter relay
The hole in the firewall for the alternator wire
The alternator wire from the alternator CB to the ammeter shunt
