The oil cooler flange was trimmed at the right corner for the one bolt.
The left side baffle needs to have a hole drilled in it for the wrench extension for the spark plug socket. A pilot hole was drilled in the baffle.
The oil pressure and the fuel pressure wires had terminal ends crimped to the wires. The terminal ends were screwed to the oil pressure transducer and the fuel pressure transducer. The oil temperature sensor wire also had a terminal crimped to it and then the terminal was screwed to the sensor.
The oil cooler flange trimmed to clear the engine mount
The hole that needs to be drilled for the spark plug socket access hole
The oil pressure and fuel pressure transducer wires
