Baker's RV-6
Date:  8-23-2011
Brief Description:  Cleaned Fuel Line Fittings/Took off Baffling
The two fuel lines that had been installed with the FuelLube were removed and the FuelLube was wiped off the fittings. The fuel lines were reinstalled.
The LightSpeed control box was screwed in place in the cockpit.
The left side aft baffle and aft left baffle were removed from the engine.
The fuel line fittings were cleaned up
The baffles removed from the engine
