The new fuel lines were received from TS FlightLines and installed. I applied FuelLube on the fittings. The hoses between the fuel pump and the transducer and then the transducer and the gascolator were screwed in place.The hose between the transducer and the carburetor were clamped in place. The FuelLube should not have been used and needs to be removed.
The new hoses
The hose between the fuel pump and the transducer
The hose between the transducer and the carburetor clamped in place
