Brief Description: Measured and Ordered New Fuel Lines
New fuel line hoses needed to be made between the fuel pump and the fuel pressure transducer and then the transducer and the carburetor. I attached the hose to the fuel pump and measured the hose length required between that and the transducer. Distance is 9". The distance measured between the transducer and the carburetor is 29.5". I called Tom Swearingen at TS FlightLines and ordered new fuel hoses. I also ordered a hose to go between the gascolator and the fuel pump. Length is 15". Tom's hoses are teflon, instead of stainless.
The fuel line out of the fuel pump
The fuel line from the fuel pump to the transducer
