Brief Description: Installing the Firewall Pass-Through
After routing the oil door shutter cable, I drilled a hole in the firewall for the pass-through. I used the paper template to locate the screw holes. I found that the 1 1/8" hole drilled using the hole cutter made an oblong hole. One of the screw holes was very close to the edge. I spent a lot of time making the holes line up for the pass-through. Finally the holes were finished and the pass-through is attached to the firewall.
