Baker's RV-6
Date:  6-11-2011
Brief Description:  Cleaned Up Bolt Holes for Oil Cooler
The two bolts on the right side of the oil cooler would not go into the nutplates. Jeff stopped out and looked it over. He saw that the washers were not cut off enough on the side. After I ground off another 1/32" of each washer, the long bolts fit properly. I tightened all of the bolts and found that the bots on the ight side were a little too long, so an additional washer was added to each bolt.
The oil cooler finally bolted to the baffle
The right side of the oil cooler
