Brief Description: Removed Cover on LSE Serial Plug from Sensor
The serial plug from the direct crank sensor needs to be run aft thru the firewall and plugged into the LSE Plasma CDI ignition module. The cover on the plug was removed, which allowed the plug to be run thru the firewall pass-through doubler and the hole in the firewall. The wires need to be removed from the plug itself in order to be run thru the pass-through.
