Brief Description: Connected Manifold Pressure Tube to Sensor/Fitting
The tubing included in Van's VMP INSTALL kit is 1/8" Tygon and is connected to the bulkhead fitting and the LightSpeed Ignition box, which I did. The manifold pressure sensor for the Dynon also needs an air input from this tubing and the required tubing is 1/4". I need to find a tee fitting that has two 1/8" fittings and one 1/4" fitting for the tubing.
Update, 5/26/11: Called McMaster-Carr and found that they have a plastic tee fitting with these requirements. I ordered a pack of ten (smallest order) from TJ.
The bulkhead fitting with the tubing attached to it
The 1/8" 1/8" tubing attached to the Lightspeed ignition box
