I safetied the primer fitting on the #1 cylinder, wrapping the wire around the oil line fitting. I redid the safety wire on the oil quick drain fitting. It was very loose, so I did it over and tightened it up. The starter wire was placed on the fat terminal on the left side of the starter and tightened. The cap cover was then pulled over.
