Brief Description: Made Support Bracket for Baffle on Cylinder #4
I cut another angle bracket that will be riveted to the side baffle for cylinder #4, left aft position. The bracket, .063" thick, had to be configured to overlay the vertical bracket in the aft corner and overlay the baffle for cylinder #2. I cut off the one angle side on the top and then bent the bracket in the vise to fit over the other bracket. I drilled a hole in the center of the angle at the other end and then cut the center so that the one side could be joggled as well. All edges were smoothed out.
