Baker's RV-6
Date:  4-13-2011
Number of Hours:  1.50
Brief Description:  Drilled Ice Drain Hole in Oil Breather Tube
I drilled a hole of 7/32" diameter about 7" from the lower end of the oil breather tube and then made it into an oval. I cleaned up the edges and used an 1/8" punch to indent the lower end of the hole. The tube was then reinstalled in place on the firewall and clamped to the engine.
The ice drain hole
The ice drain hole
The ice drain hole
The ice drain hole
The oil breather tube clamped in place
