Baker's RV-6
Date:  4-12-2011
Number of Hours:  4.00
Brief Description:  Add Stiffener Angle to Baffling/Oil Breather Tube
I initially cut off an angle bracket of .040 x 3/4 x 3/4" for the aft left corner of the baffling where the oil cooler will be installed. After positioning it in place, I noticed that the screw hole on the left baffle will just barely be covered by the bracket, thus not providing much support for the screw. I made another bracket of .063 x 1 x 1" for that corner and drilled it to the left side baffle. I pulled out the oil breather tube and positioned that in place on the firewall.I put it in an Adel clamp and screwed it in place, then I read the drawing OP-27 for the installation. The lower end should be beveled and an ice drain hole should be drilled in the tube between 6 and 9" above the bottom. I cut the radiator hose to the proper length for each end and installed the clamps. After reading the instructions, I pulled the tube out. I used the Dremel cut-off wheel to bevel the tube end and smoothed the edges on the Scotchbrite wheel.
The left corner with the thicker bracket
The oil breather tube
The oil breather tube screwed in place
