Brief Description: Trimmed Front Baffling and Left Side Baffles
I trimmed the two front baffles and hopefully left enough extra material. I also trimmed the two left side pieces more with the cutoff wheel in the Dremel. I cleaned up the aft corner of the plenum and that allowed it to slide deeper into the baffling. I also saw that the aft left rear baffle flange needed to be trimmed allowing the plenum to move farther aft, which I did.
