Baker's RV-6
Date:  3-24-2011
Number of Hours:  0.50
Brief Description:  Installed Oil Quick-Change Drain/Baffle Trimming
I cut the safety wire off the oil drain on the right side of the oil sump and removed the plug. Luckily I had the bucket in place under the engine to catch the oil. About two cups of oil came out before I was able to install the quick-change oil drain. The drain is a Saf-Air F P5000 from Van's. I applied the anti-seize and tightened the drain. It needs to be safetied.
The oil quick-change drain installed
The oil that drained out
The baffle trimmed around the engine mount
