Brief Description: Primed Left Side Brace/Riveted Receptacles
I inserted clecoes in each hole on the left side of the top cowl and then drew circles around each cleco for reference marks. The reference marks will be used when the holes are enlarged with the Unibit for inserting the grommets. The left side brace was Scotchbrited and cleaned with MEK and lacquer thinner and then primed. I used the pneumatic squeezer to rivet the receptacles to the brace. The brace was then clecoed to the lower cowling. The top cowling was positioned in place and the camlocs were tightened up. The left side of the top cowling now looks like more sanding needs to be done.
