Brief Description: Installed Spinner/Camloc Holes in Support Braces
I filed the top edge of the left side support straight and then smoothed the edges on the die grinder. I had Bernie Ockuly look over the cowling installation. We put the spinner on the prop to check the height of the cowl re the spinner and found everything looked to be in alignment. We took the cowl off, as well as six of the eight support braces for the cowl. I used the jig that came with the Skybolt camloc kit to drill the rivet holes for the camlocs. First, the initial holes had to be upsized to #30, and then the jig was used. All holes were drilled in the six support braces for the camlocs.
Visitors-Steve Vilimonovich, Joe Walker, Joe Walker, Jr.
The spinner positined in place with the cowling
The clowing, spinner and me
The support braces with the initial camloc holes drilled
