Brief Description: Cut out Subpanel for Radio Stack
Measured location and position of the radio stack on the instrument subpanel. Drilled corner holes and then cut the sides out using a cutoff wheel in the Dremel. Cleaned up the edges with the die grinder.
The radio stack cutout in the subpanel
The center rib needs to have a cutout for the radio stack, as indicated by the Sharpie line
