I made spacers and then drilled and dimpled them for riveting to the fuselage floor. The #1 comm antenna bracket will be moved to the next inboard bay and these spacers cover up the aft two holes. I primed the bracket for the flap sensor. The elevator bellcrank and push-pull tube were........
Spacers riveted in original holes for the #1 comm antenna
