Brief Description: Installed Springs on Brake Master Cylinders
I received my McMaster-Carr order for springs, plastic bushings, and nuts. I found the component list on Van's Air Force.net. I installed these on the master cylinders because builders have reported that sometimes the brakes stick after application and the master cylinder does not fully extend. Hopefully, by using this set-up, I won't have this problem. I placed the plastic bushings on the master cylinder first, then the springs, and then the nuts, which have set screws and were tightened using an Allen wrench.
The springs, plastic bushings, and nuts
The master cylinders prior to the addition of the springs
