I replaced the screw in the pitch servo per the TruTrak Service Bulletin. I installed the AN3-56 bolt in the right rudder pedal and installed the washers and castle nut, with the cotter pin.
Visitors-Emmett Starks, Doug/Mark Robison
Pitch servo and the replacement screw
The new screw for the TruTrak
The right rudder pedal drilled in place for the AN3-56 bolt
