Brief Description: Drilled Holes for Static Line Routing
I drilled 1/4'' holes for the static line routing along the left sidewall thru the seat back brace bulkhead and the other brackets. I ran the static line thru the holes. I had some trouble getting the plastic tubing thru the holes in the forward bulkhead, so I cut the end of the tubing to a point to help guide the tubing thru.
The hole drilled thru the seat back brace bulkhead
