Brief Description: Made Fuel Vent Tubing/Installed Fuel Vents
I drilled holes in the corners of the fuselage and drilled them to size with a Unibit. I installed the fuel vents from Bonaco and tightened them in place. I measured and cut off a length of tubing to run between the fuel vent and the fitting on the side of the fuselage. I bent the tubing to go up the side of the fuselage, across the longeron and down the corner of the fuselage/firewall.
