I pulled out the Vetterman exhaust components for installation. I hung the exhaust on the studs and applied Permatex Anti-Seize lubricant on each bolt. I used my torque wrench and set it at 125 in-lbs of torque. I could not reach some of the nuts, so after investigation on VAF website, I went to Sears and bought some flex sockets, 3/8'', 7/16'', & 1/2'', and a 10'' drive extension. Using the 1/2'' flex socket with the drive extension, I was able to torque all of the nuts.
Visitor-John Fink, with Jeff
Spread Permatex on each stud
Torque wrench with the drive extension and the flex socket
