Brief Description: Made New Fuel Line betw/Electric Pump and Fitting
I picked up two more washers, AN960-716, from Fred Coblentz. These are the two needed for the last engine mount bolt. I ordered replacements from Doug Robison. I installed the two washers on the top left bolt. I cut and bent 3/8'' tubing to be installed between the electric fuel pump and the new firewall fitting. I installed the firewall fitting with a washer on the firewall side and tightened it. I installed a 45° fitting into the In port of the gascolator and a straight fitting into the Out port. I started to work on a hard fuel line between the firewall fitting and the gascolator. Joe Walker suggested that a flexible line might be used instead. I pulled the exhaust system out for installation.
Old and new, longer fuel line tubing
New fuel line fitting
Fuel line tubing between the electric pump and the fitting
