Brief Description: Tip-up Mod Components Install/Drilled Anchor Block
I cleaned up the tip-up mod components on the Scotchbrite wheel. I placed painter's tape on the top and side each block and marked lines on the tape indicating the pin angles. I drilled holes in the C-667 rear anchor blocks for the canopy rear pins to be inserted. I started with small drill bits and enlarged the openings to 1/4''.
The tip-up mod components after smoothing and rounding the edges
