Brief Description: Positioned and Drilled the Rear Anchor Blocks
I positioned and drilled the plastic canopy rear anchor blocks to the brackets on the drill press. I drilled the holes in the blocks up to #10 bit size and the holes in the brackets to #12 for the AN509 screws.
The left anchor block in position on the longeron
The right anchor block in position on the longeron
The canopy latch sits low relative to the locking pin
