Brief Description: Installed the Rod for the Canopy Rail
I drilled out the bottom rivet in the top center of the F-607 bulkhead and then drilled that hole up to 1/4" size for the rod from the canopy rail. I inserted the rail and then notched the top baggage bulkhead for the rail and the nut attached to it.
The rod positioned between the canopy rail and the bulkhead
The top baggage bulkhead notched out
The baggage bulkhead in place with the notch for the support rod
