Brief Description: Flap System and AOA Switch Wiring
I crimped the FPS wires to the wires going forward to the panel. I also crimped the FPS wires to the flap motor wires. I crimped blade connectors to the AOA switch wires. The smoke system wires were connected to the reservoir. These wires will be run back behind the baggage bulkhead and thru blue tube #3. After crimping all of the wires together, I used wirewrapping to consolidate wires to clean up the area.
I started looking at a location for the smoke system remote switch. I am going to probably place the switch on the panel above the master switch.
I plan to run the FPS, AOA, and smoke system wires thru the center section of the spar.
I talked with Jason Smith-Aerotronics re the headset jacks. They had sent me mono jacks, instead of stereo jacks. Jason will send stereo jacks to me. I also ordered two LEMO plugs for the LightSpeed/Bose headsets that run off of ship's power.
