Brief Description: Riveted Gascolator Bracket/Springs on GPS Wiring
I riveted the gascolator bracket to the firewall. I used Fuel Lube and inserted a plug in the priming hole on the top of the gascolator. I used thread sealant on the drain plug and inserted it into the gascolator. I purchased some springs from Home Depot and wrapped two of them together around the GPS antenna wire and the Fuel Guardian wiring. I did this to try to keep the GPS wire from hanging down.
The gascolator drain plug
The gascolator and bracket in place on the firewall
