I added another Adel clamp to hold the cooling fan primary wire just prior to the splitter. I placed it on one of the screws for the AOA box.
I decided to attach the ELT bracket to the center fuselage rib that the pitch servo is on, just aft of the baggage bulkhead. I drilled #19 holes and riveted nutplates to the rib for the two bottom holes. I screwed the bracket and straps in place and used washers and nylocks for the two upper screws.
Walt Halloran dropped off the canopy roll bar and frame after painting. He also painted the two control sticks and the canopy rollers.
