Brief Description: Tunnel Cover Mod/Inst Top Skin Work
I took out the interior after the shop tour and covered up the wings and the engine. The cam that I had installed on the flap actuator interferes with the baggage area tunnel cover, so I cut out a notch in the cover to allow the cover to fit around the cam. I took the instrument panel top skin off and measured off the locations of the angle brackets that need to be riveted to the top skin. I drilled pilot holes in the top skin, clecoed the skin in place, then drilled the skin to some of the brackets. I countersunk the brackets.
