Brief Description: Tapped Roll Servo Control Rod/Wingtips
I tentatively positioned the roll servo in the outboard left bay under the left seat and attached the control rod to the control stick. I checked for problems with movement of the servo arm and the control rod and found that the lightening hole had to be altered somewhat.
I worked with Jeff on the fiberglass tips and started with cutting out holes in the tips for the nav/strobe lights. I used a bit on the Dremel tool to cut the holes for the Van's nav light extensions to be glassed inside the tips.
Roll servo positioned in the left outboard bay
The roll servo control rod attached to the servo and control stick
