Brief Description: Put Away OSH Purchases/Panel Offset Bracket
I put away the supplies and tools I purchased at Oshkosh, I took off the front top skin and deburred the two holes drilled thru the skin, the subpanel and the spacer and bracket. I measured the gap that needs to be shimmed to be 7/16'' down to 0''. I marked the subpanel where the bracket and the shim will go thru and drilled pilot holes.
