Brief Description: Talked with Darryl-Van's re Offset Center Rib
I talked with Darryl-Van's re the problem with the instrument panel center rib being offset and not allowing the canopy support bar to be centered. I put forth to him my idea of inserting a wide shim, up to 3/8" wide at the aft end, riveted between the rib and the bracket, and he thought that there should not be any problem with that.
