Brief Description: Leading Edge of Elevator/Antenna/Roll Servo
Took the left elevator off a few times to try to reduce the rubbing of the leading edge on one rivet. Used the pneumatic squeezer to try to squeeze the rivet more, but there is still slight rubbing.
Drilled out the left comm antenna bracket and had a problem with one rivet. Enlarged the hole. Positioned the roll servo in the left bay and found that the servo rod is at least two inches too long. Cut off two inches and now have to tap that end.
Drilled the comm #1 antenna bracket out
The roll servo and the comm bracket in their new positions
