I installed the brake reservoir to the firewall and torqued the bolts. I installed the brake fittings on the master cylinders with Loctite PST-565 thread sealant. I also installed the brake lines to the master cylinders and the brake reservoir in the same manner.
Bonace brake lines installed on master cylinders
Brake lines going thru firewall into brake reservoir
