Brief Description: Primed and Painted Interior Pieces
Cleaned, primed and painted interior pieces. I used up the SW 988 primer and bought NAPA 7220 primer. It is also acid-etching. I discovered that areas where I had used the die grinder and Scotchbrite really stood out when painted. I used the red Scotchbrite pad to go over areas on unpainted pieces to try to feather the areas.
