Brief Description: Started to Rivet Aft Top Skin to Fuselage
Sprayed primer on a few areas that were missed on the top skin. Used files and different Scotchbrite wheels on the die grinder to bevel the side edges of the top skin. Clecoed skin to fuselage. Riveted the skin to the top of the F-611 bulkhead and the stringers, the F-612 bulkhead, and part of the longerons on each side.
Notes to check: I did put a smiley on the skin at the aft end of the right stringer. I need to hit the rivets along the right longeron again. These rivets are longer and I didn't hit them long enough.
