Brief Description: Attached the Andair Fuel Selector in Position
I beveled the inside edge of the hole drilled for the fuel selector in the cover. This allows the selector to lie flat. I drilled holes in the cover for the attaching screws or bolts, don't know which. I attached the selector to the cover, the floor panels in place, and the cover to the floor. I also screwed on the SS flexible fuel lines to the selector. Now I need to determine if these lines can be used or if I should bend tubing.
