Brief Description: Positioned Flap Cam & AOA Sensor/Rivet Top Skin
I positioned the split cam that Bob Sprang made for me onto the center of the flap actuator. I made a bracket that will be attached to the EF-602 aft bracket. This bracket will have the AOA flap sensor attached to it. Emmett and I worked on determining the proper amount of the angle to be ground into the cam. The AOA sensor will determine when at least 13 degrees of flaps will have been deployed for the AOA indication. After much trial and error, we came up with a good angle on the cam and a good position for the AOA sensor.
I completed the riveting of the aft top skin with Joe Walker's assistance. I inserted many spacers between the skin and the F-611 bulkhead to help round out the skin as we riveted. Bolted the shoulder harness anchors to the longerons and applied torque seal to the bolts and nuts.
