Brief Description: Finished Assembling the Fuel Selector Cover/Primed
I drilled two pilot holes in each of the top of the side covers for the screws. I positioned the tank cover in place and clamped everything in place. I drilled the holes in the side covers and the tank cover to #19. I also did more trimming in areas that needed it. I drilled holes in the sides of the trim cover flanges for the nutplates and countersunk them. I used the Scotchbrite pad on all of the pieces and then cleaned them up with enamel cleaner. All of the fuel cover pieces and the two F-699 brackets were then primed.
