Brief Description: Need to enlarge F-639/640 control stick holes
I put the seat floor in on both sides, as well as the seat backs and the cushions. Checked the access hole in the seat floors, F-639 & 640, for range of movement. The forward portion of the access hole needs to be enlarged approximately 1/2-3/4'' for full range of stick movement.
I made an angled brace to attach the front of the bracket to the cross rib and clamped it in place. Drilled access hole in the firewall for the brake reservoir fitting. Cleaned up the top skin with enamel cleaner and then primed it.
