Baker's RV-6
RV-6
Riveted Control Rod Bearings/Brake Plate Drilled
Riveted VA-11?? to the F-690 control rod and the rod-end bearing to the F-689 control rod. Drilled the F-601TD brake plate to the firewall.
Visitors-Bernie Ockuly, Craig Coben, Jeff Paden
VA-11?? riveted in place
F-689 control rod with rod-end bearing
F-601TD drilled in place
RV-6 Home
5540
544
Control Systems
Cowling
164
199
666
124
570
Flight Training
1225
Inspection
Instrument Panel
142
227
256
Shop Construction
Systems
Weighing
1334
Wiring
126
216
