Brief Description: Changed tubing in floor for wire runs
Pulled out the black split tubing under the floor/baggage panels, based on Bernie Ockuly's recommendation. He suggested using blue solid tubing instead. This would reduce the chance of any wire getting caught in the split tubing. I had to enlarge the holes, so this was done with the 3/4'' Unibit and then a sanding disc on the Dremel. I ran the blue tubing in place, after cutting it into four-foot lengths. I drilled and riveted K1000-08 nutplates into the F-626L & R ribs to attach cushioned clamps (MS21919-WDG14) to keep the tubing from moving. I also drilled the F-625L & R ribs for nutplates.
