Brief Description: Drilled NACA Vents into position/Brake plate drill
Drilled both NACA vents in position on the fuselage and deburred all holes. Cut out a piece of .063'' scrap to make the F-601TD brake plate for the brake lines. This was drilled to the holes in the firewall. Holes were deburred.
