Brief Description: Cut out Left NACA Vent and started Right Vent
I taped the cutouts for the air vents to the fuselage sides. I traced the cutouts and drilled holes in the corners. Used the Unibit to enlarge the holes. Used a cut-off wheel to cut out the vent areas. Used files and sanding wheels in the Dremel to enlarge the left vent to the proper size. Cut out the basic shape of the right vent.
