Brief Description: Drilled Rudder Pedal Brackets in Place
I drilled the rudder pedal brackets to the fuselage side brackets to 3/16'' size. Installed the bolts but not the nuts and washers. I checked the positioning of the center pedal bracket under the F-6118 bracket and drilled the bracket in place.
